Why some profiles go to Pending mode on their own even if I re-publish them and then show the same expiration date and never expire? http://awesomescreenshot.com/0844hkhkd8 thx.
Hello ! Expire means all the listings go in pending mode. You have to update and change dates manually while publishing again. Thanks & Regards Pramod Patel
Those listing don't expire! They still show days to go and the amount of those days are not changing. I only have a problem with three such listing. Beside Draft mode means the listing is expired and not the pending mode… http://awesomescreenshot.com/0aa4j22kf1
Hello, Please provide the following information listed below. This Thread Link: Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] Thanks & Regards Pramod Patel
Hello ! You can publish them from dashboard. http://screenpresso.com/=ZNRG Thanks & Regards Pramod Patel
Yes, I know that and I do it all the time manually. But those accounts I mentioned are going back to pending mode on their all the time… And that was my question
Hello ! It may be occurs because the author of this post edit this listing. When the the author will make edit their listing or update their listing it will go on pending mode. Thanks & Regards Pramod Patel
Hi, We need WordPress admin credentials to figure out the issue. Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will try to fix your issue. Regards, Akbar InkThemes.com
Hello, We have successfully received your credentials and is being forwarded to the concerned department, will get back to you with a positive response ASAP. Your patience will be highly appreciated, Warm Regards! Akbar InkThemes.com
