I think it's based on Logistics so I write here. I purchased this theme and I made clean installation. I imported demo data and it's ok. In page book a cab ... the booking form doesn't appear. In the front page, bookin form is showing but seem that it's not working. I installed Google Maps API key correctly
You are requested to check your widgets (Dashboard->Appearance->Widgets) Please make use of Booking Widgets under Home Page Widget Areas. I hope the above solution will work for you. If you still need our help, please share your WordPress admin login details at [email protected] We will check and do the needful. Regards! Akbar InkThemes.com
