I did a fresh install, ran site through gtmetrix.com and got a 58 for Google and 72 for yahoo. I use wordfence and went to try and activate the Wordfence Performance feature and getting any error. See below. also over 3 second load speed with a clean install, not adding my images. I even tried to install the smush-it plugin to optimize and when i install it goes to a white screen. any help would be appreciated # BEGIN WordPress RewriteEngine On RewriteBase / RewriteRule ^index\.php$ - [L] RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteRule . /index.php [L] # END WordPress
Hello, Blackrider theme is compatible with "WP Smush.it" plugin. I think your other plugins are conflicting. So deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s). I hope it will work. Thanks & Regards Nitesh Raghuwanshi
