Dear Support team, I have noticed on a couple of my inkthemes sites that various combinations of caching plugin and SEO plugins clash and cause some strange issues. As an example: On separate infoway and appointway theme sites, I noticed that with Yoast SEO and W3 Total Cache plugins activiated at the same time, the mobile menu fails to function. Are you aware of any cominbation fo SEO and Caching plugin that will function properly. Looking forward to your response. Pat.
Hello, InkThemes multiple users makes several combinations of plugins but sometimes due to version updates of these plugins issue is created because jquery of plugin conflicting with each other and makes many failures issue. So we suggest you to use alternative of any one plugin from them and check there combination. I hope it will works.
