Can I adjust the product display in Compass Pro?
Discussion in 'Compass WordPress Theme' started by earnestmarket, Dec 12, 2016.
  1. earnestmarket
    earnestmarket Member
    Hi. I'm wondering if I can change the location of the product description in Compass Pro. Right now, the image shows on the left and the title on the right, followed by the price, add to cart, and category and tags. The actual description is below all of that. Is there a way to put the description up between the add to cart button and the category/tags?
    Alternatively, can I move the category and tags below the description? The images are big enough that the description is well below the fold when the product is loaded and I'd like to get it up higher if possible.
    Thanks!
  2. Naveen
    It seems you are using WooCommerce plugin and want to change the layout of the product details page in the theme.
    For your information, that is not possible as the changes will require some WooCommerce source code changes.
    You can contact the support forum of the WooCommerce and do it your self.
    Warm Regards!
    Naveen Kolhe
  3. earnestmarket
    Yes, that is true. Thanks, I'll ask them!!
