Can I merge Home Page 2 Cols section
Discussion in 'Figero WordPress Theme' started by bizgirl, Nov 8, 2013.
  1. bizgirl
    bizgirl Member
    Hi there
    I have a video set in the HP 2 Cols section but it is too small for viewing.
    www.smartglobalpay.com
    Is there a way to either:
    - merge the 2 columns, or
    - widen one column so I can make the video larger for viewing
    Also is it possible to highlight text in the theme. For example in the first column I would like to highlight couple of words in red or yellow.
    eg: I would like to highlight the word HERE in yellow in this sentence - Find out HERE how i-Payouts UNIQUE payment system can help you REDUCE your overheads.
    Thanks again as always,
    Maggie
  2. bizgirl
    bizgirl Member
    Sorry guys one more question. I would like to embed my youtube video on the home page inside an image of a monitor or TV image to make it look more professional. Can you tell me how I would do this?
    Many thanks..
  3. Gourav
    1.For your first issue
    2. For your second issue
    Paste this code in Custom CSS
    u {
    color: red;
    3.For your third issue
    Go to
    Appearance -> Theme Options -> Slider Settings
    And put the embed code of the video to the the "Slider 1 Image" text box and save the settings.
    It will show the video in the home page, and you have to adjust the width and height of the video which you can adjust in the embed code of the video.
  4. bizgirl
    bizgirl Member
    Many thanks Gourav, I appreciate your quick response.
    With regard to Point 3, I would like to add an image such as this and then put the video inside so it has a professional look. Im not sure how to do this and would appreciate any advice on how it can be done.
    With appreciation and gratitude,
    Maggie
  5. Piyush
  6. joswebsitedesign
    joswebsitedesign Guest
    Adelaide, SA, Australia
  7. Gourav
    It is not possible to merge frame with video in the homepage slider area, but you can add video with frame in other pages, For that you can search video frame plugin from WordPress.org and upload it.
  8. bizgirl
    bizgirl Member
    Thanks Gourav... Hope you had a lovely weekend..
