Hi Sooraj, Greetings from InkThemes, You would be glad to know that YES, you can add your own products with this theme. After installing the Digital Affiliate Box plugin (inbuilt in the theme), you can follow the screenshot given below to add products :- You can also refer to the documentation provided with the theme for more help. Should you need any further assistance, don't hesitate to contact us. Thanks & Regards! Nitin InkThemes.com
Hi Sooraj, Greetings from InkThemes, By default, the added products get displayed/featured on the homepage itself. If you are facing any trouble in displaying the products there, just provide us your website URL so that I could assist you better. Looking forward to hear from you. Thanks & Regards! Nitin InkThemes.com
Thanks for the details.. We will get back to you soon.. Your patience will be appreciated, Thanks & Regards! Priyanka InkThemes.com
Hi, Thank you for getting back to us. To set the featured image for your post to be displayed on the homepage, just go to edit the concerned post and then set the featured image from the bottom right corner of the page. You can also follow the attached screenshot below. Hope this helps...! Thanks & Regards! Nitin InkThemes.com
