I've used Special Recent Posts in Cloriato without an issue, but when I try the same procedure in Poloray, the left panel is just blank. If there is a way to make this work, what is it?
Hello, Our theme are compatible with almost all the plugin available in WordPress.org but there are thousands of plugin available on WordPress.org and some are regularly updating and some are not updated from many years therefore it is not possible for us to check every plugin with our theme, So you can search any alternative of that plugin. Or You can also contact to plugin related support forum. They will help you. Thanks & Regards Gourav Shrivastava
