Cannot load Pro Colorway
Discussion in 'ColorWay WordPress Theme' started by nat8888, Nov 26, 2015.
  1. nat8888
    nat8888 New Member
    I am having trouble loading the Pro version that I just bought. I've paid and added it in the theme folder then when I used 'add new' it said that colorway was already there.
    What am I doing wrong?
    Here are the steps involved in doing so:
    Download the ColorWay Pro theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder colorwaytheme like colorwaytheme_new,
    Again, you would need to create a zip file of that renamed folder (say: colorwaytheme_new.zip),
    Then, activate your theme,
    This way you can install and activate your PRO version in your site,
    Hope you find it helpful,
    I would be glad to assist you further,
    You are most welcome to InkThemes ...
    Enjoy your theme:)
