I'm not able to create multiple menus within Blackbird Pro under the "menus" section of wordpress. We purchased the Pro version because it promised this feature. I read through the forums and it looks like this has been an issue on other Ink themes as well. I'm looking for the Home Page to have it's own menu and then within the site have different menus pertaining to the specific page. I'm also still seeing under the "menus" section the phrase "Your theme supports 1 menu. Select which menu you would like to use." that is not what was promised for paying for the Pro version of Blackbird. Please Help.
Sorry, I'll try to break it down even further. My site address is http://jpass.laptopsentry.com. I'm not able to create multiple menus in my Blackbird pro theme. The "menus" section can be found under the "appearances" tab within word press. Within the "menus" tab you build custom menus by checking off what pages you would like to include and them organize them in the order and decide which pages are "parent" pages or not. After you save your custom menu you select on the top left which saved custom menu you would like to use for the site on that specific page. It allows me to create several custom menus however I can only select one and it will use that one menu throughout every page on the website. For some reason it says "Your theme supports 1 menu. Select which menu you would like to use." When we bought the Pro version of Blackbird it said we would be able to have as many custom menus as we need. I should be able to create several custom menus and assign those menus to specific pages within my website. How do I do this or why is it not allowing me to do this. Also the menu is the entire colored bar of links to pages across the top of the website page.
Hello, The theme sharing same header for all pages that's why showing common menu for all pages, If you want to show different menu on different pages, than you can use Dynamic Widget plugin from WordPress.org and then go to Appearance > Widget and drag custom menu widget in primary widget area and select different custom menu for different pages. Check link for reference http://www.inkthemes.com/easily-control-appearance-of-widgets-on-your-wordpress-pages/02/ I hope it will helps you.
