Can't get qtranslate to work
Discussion in 'ColorWay WordPress Theme' started by johced1974, Aug 23, 2016.
  1. johced1974
    johced1974 New Member
    I checked you site and noticed that all the content you have entered is in translated format...And as for the below areas like: blog and footer so if I am not wrong you didn't put any content in that fields so you are requested to put your content over there first and check after that..
  3. johced1974
    Sorry..didn't get you..
    Could you please explain it a bit more so that I can assist you accordingly..?
  5. johced1974
    I don't know how to explain more. Look at my pictures please. I entered the proper code for the text to be shown in a specific language. However, as you can see in the other picture, it shows all the languages at the same time. If I selected English the text should only be in English.
    I followed the instructions here: https://www.inkthemes.com/how-to-translate-your-wordpress-website-using-qtranslate-plugin/
  6. priya
    Sorry for the inconvenience..
    You can use either of these plugins Polylang or LocoTranslate WordPress plugin in which you can translate from the backend instead of qTranslate,
    Or you can create a PO file in your desired language by following the steps mentioned in the tutorial:
    https://www.inkthemes.com/translation-of-wordpress-theme-using-po-file/
