Can't turn on front page features
Discussion in 'Appointway WordPress Theme' started by cbpayne, May 27, 2018.
  1. cbpayne
    cbpayne New Member
    I have added images for sliders etc etc under slider settings
    I have added the content to the Home Page Feature areas
    Have static page set to home page
    Nothing shows up on the home page.
    In post #10 of this thread: https://www.inkthemes.com/community/threads/how-to-change-home-page-to-a-static-page.22543/
    are these instructions: "Dashboard->Appearence->Theme Options -> General Settings->) and trun of the Front Page On/Off option, Just follow the attached screenshot."
    I see no option anywhere and under general settings for that and I do not have that option to turn front page off/on
    I am using the PodiaCare ProVersion: 1.2.3
  2. akbar92
    Thanks for contacting us,
    Just for the confirmation, you want to set the homepage as a static page or your latest posts?
    Akbar
  3. cbpayne
    cbpayne New Member
    Static page
  4. akbar92
    Just go to (Dashboard->Settings->Reading) and set the homepage as A Static Page then select the desired page. Please have a look at the attached screenshot.
    Akbar
  5. cbpayne
    cbpayne New Member
    That is what I was doing and it still not working.
    HOWEVER, it does work if I select "Your latest posts" as the home page!!! - I do not see why it is working when I do that!
    Now have another problem: in the theme options - none of the upload image links work. Click on them, nothing happens.
    (deactivated all plugins and that did not help)
  6. akbar92
    Greeting from InkThemes,
    We need WordPress admin credentials to figure out the issue.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    Akbar
