Captcha displaying error messages
Discussion in 'Slice WordPress Theme' started by honory2009, May 15, 2016.
  1. honory2009
    honory2009 Member
    I have activatenaed lead capture plugin from this site wowtz.com. However, when you turn on recapture you ended up with this screen shot. Is it possible to have the same lead capture with sum-up captcha like on this site www.videozetu.com?
    thanks
    Honory
    Hi, Honory..
    You just need to fill public and private keys under lead form setting option of your dashboard..
  3. honory2009
    honory2009 Member
    Hi Priya,
    I put both keys on my site www.wowtz.com. However, they are not the same as this lead form at this site www.videozetu.com
    thanks
    Honory
    Hi, Honory..
    It seems that you are talking about the google captcha code format...
    So if I am not wrong with your concern....would like to tell you that the captcha code is generated from google so we don't have any control on that..
    Hope you will understand..
