CAPTCHA for ink appointment on home page.
Discussion in 'Appointway WordPress Theme' started by mikeusa888, Aug 14, 2013.
  1. mikeusa888
    mikeusa888 New Member
    hi,
    is there anyway i can add a captcha for spam on the appointment that show up on the home page. So far, all i got is spam appointment not the real customer appointment. Please help.
    Thank You.
    For this go to the
    Appointments > settings > Other Settings > Captcha on/off
    On captcha from there.
  3. mikeusa888
    i do not see other settings. all i got is Appointments > settings > payment settings and manage currency.
  4. Piyush
    Firstly go to the Plugins >Installed Plugins panel in your dashboard and delete the Ink Appointment Plugin from there.
    And then download the updated copy of Appointway Theme from the members area (http://inkthemes.com/members/member)
    and, upload and activate it in your dashboard.
    See the link for reference.
    http://www.inkthemes.com/how-to-update-a-premium-theme-by-inkthemes/05/
    And then activate the Ink Appointment Plugin in your dashboard
    and go to the Appointments > settings > Other Settings > Captcha on/off ,
  5. rosy
    rosy Member
    Hi Piyush,
    I tried what you suggested - deleting the plugin and then reinstalling the latest (1.1.0) version of the theme and this is the error message I am getting now when I try to activate the plugin see screen capture below - what do I do with this problem please?
  6. Nitesh
  7. rosy
    rosy Member
    I received a message that told me to delete again, re-download the theme, reinstall the theme, reinstall the plugin then activate - I think the problem was that I had my child theme active when I installed the plugin so this time I activated the parent theme activated the plugin made sure it was working then activated the child theme and reactivated the plugin.
    Now the plugin is fine the captcha is there but all the customization I had done one the plugin forms is gone and I could just cry - this represents hours and hours of work!
  8. rosy
    rosy Member
    Is there a way to preserve plugin customizations when you update a plugin like a child theme does for theme customizations?
    thanks,
    Rosy
  9. pauljw
    pauljw Member
    Thats why I did not delete is as sugested. I have loads of spam every day because of this. Irritating!
  10. Piyush
    It is not possible to do so but you can save your customized file manually.
    You can save your plugin customized file in your system and then update your plugin.
    And after that do the same customization in the updated plugin file by comparing the previous customized file.
