1) I can't setup carousel. It does not show in home page or in Theme Options. It was available in trial version. How do I get it to work in PRO? 2) Also the margins on Mobile are TOO wide. How do I make the as small as possible? See attached image. 3) It is very difficult to see links. How do I change link color, as well as <p> font color? How do I change Featured Page Heading font size / color? My site: http://www.metalroofingma.com/ Thank you
1.For your first issue Homepage carousel shows the post, Create a post with an image, It will automatically display at your homepage. 2.For your second issue Paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: @media only screen and (max-width: 480px){ a.btn { margin-top:0px; margin-bottom:0px; } .contactinfo span.calldetails { font-size: 15px; } } 3.For your third issue Paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: .feturebox .featurebox_inner .featurebox_desc h2 a{ color:red; font-size:20px; } p{ color:red; } a { color: red; } This will solve your issue
@ Gourav, Thanks for response. I will add some posts later to test out the carousel. #3 works, #2 - I see no effect from adding that code. Also the code calls for 0 margins on top and bottom. I mainly want zero margins first of all on SIDES, and then on top. The bottom is irrelevant. Also, the code implies that max width is 480 pixels. then it's not a responsive theme. responsive should adjust to the screen resolution. My resolution in the attached image is 720p wide x 1280p high On 560 x 940 it looks just about as bad. Basically I want to use all of mobile phone screen and not waste that precious space. And I have another question / problem. I embedded youtube video. Embedded size is 480 x 360 On mobile I can only see 1/2 the payer, and it does not re-size (responsive thing) with he rest of the theme. Other free themes do this flawlessly. Please see the attached screenshot. (it's Galaxy Note 2 screen at 720x1280) So, at this point I need to get rid of margins on the sides and top, and fix video sizes on mobile.
Replace your current Youtube iframe code with the code given below Code: <iframe width="75%" height="360" src="http://www.youtube.com/embed/PWo6ISjg_Ho?feature=player_embedded" frameborder="0" allowfullscreen></iframe> This will solve your issue.
Gourav, you ignored my question about side margins on mobile, with screes resolution wider than 480px Also, 75% width on youtube player is NOT a solution - please fix theme!
