Hi. I am not aware of any misstake but the images on my carroussel (home page) are not showing. Can you tell me how to fix it? URL : www.zorgvoornop.nl
Hello, Download a fresh copy of latest theme from members area and upload it to your website. That will resolve your issue. Thanks & Regards Yogesh Bhade
Hello, May be you have comment or delete code in front page.php which show images on slider. download a fresh theme and match their front-page.php file with your current installed file and make correct the slider code from there. Thanks & Regards Pramod
Not only the slider pix disappeared but also the right widget area doesn't show. I tried reinstallation but failed. Am I required to delete the exisiting installation of Geocraft V2 before reïnstalling it again? I am afraid to lose my content and work which was built up over one month. Please advise.
Hello, You have also removed your side bar code. Use code from new downloaded theme file front-page.php and make changes in your installed theme. thanks & regards Pramod
You are asking too much of me, I am not competent here. I would not know how to do it and probably makes matters worse. Is it possible for your support staff to do it for me? I would be pleased. The problem may have to do with an earlier advise upon a translation issue as follows: You will find those words in following files so change that words in following file according to your language. 1. install.php ( in this file you can change post title in your language. 'post_title' => __('Contact Us', THEME_SLUG), ) 2. template_path.php 3. listing_type_lang.php 4. controls_path.php It will resolve your issue. Thanks & Regards Yogesh Bhade
Hello, Please provide the following information listed below. Thread Link: Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] Thanks & Regards Pramod
Hello, Issue regarding to slider and sidebar has fixed. For your translation issue please use https://wordpress.org/plugins/google-language-translator/ Thanks & Regards Pramod
