Catastrophic issue when renewing listings
Discussion in 'GeoCraft WordPress Theme' started by rogerb, Apr 28, 2016.
  1. rogerb
    rogerb Active Member
    I have seen someone else report this but it has now happened to me.
    I had just inserted a listing as an administrator with no problems.
    Still logged in as an administrator I went to the user dashboard.
    I renewed about 12 listings and the went back to the IDE to publish them as they were now in draft mode.
    I selected all with the select all check box and selected edit in the dropdown menu and click apply.
    I set the dropdown menu to published and click OK
    All listings were published but the picture from the last listing inserted was now updated into all the selected listings as was the address from the last inserted listing.
    This is disaster and I now have to revert to a backup to repair this issue!
    Your comments please as this is unfortunately reproducible!
    Roger B
  2. Naveen
    Hi Roger,
    We will check the same at our end will get back to you soon,
    Your patience would be appreciated,
    Warm Regards!
    Naveen Kolhe
  3. rogerb
    I had to renew 72 listings yesterday and I carried out the same actions (without adding any listings in first) and it all went OK.
    It seems that you have a memory issue that is carried over if you insert/amend any listings first!
    Hope this helps you to find the issue Naveen and any others with the same problem of updating large numbers of listings!
  4. Naveen
    So kind of you Roger! Thanks,
    We have forwarded this thread to the concerned department and will check at our end,
    Have a great day:)
    Warm Regards!
    Naveen Kolhe
