Centering Images
Discussion in 'Squirrel WordPress Theme' started by 1stopnonprofitshop, Sep 15, 2016.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
  2. 1stopnonprofitshop
    Not sure if this accidentally got missed...just wanted to see if there was a solution.
  3. nitin
    nitin Guest
    To center the images properly, first you need to remove the "margin-left: 202px;" CSS which you have used. This is an incorrect way of using the element centering CSS. Instead, use the custom CSS given below:-
    .content-bar img {
        margin-left: auto;
    Hope this helps...!
    Nitin
