Change background to hex color code
Discussion in 'ColorWay WordPress Theme' started by jarkan, Mar 26, 2013.
  1. jarkan
    jarkan New Member
    Hi!
    I would like to change the Colorway Theme background to a hex color code. (Instead of using the free background patterns that came with the theme.) How do I do that? For example to #E5FECC.
    Ideally I would like to match the background colour to the theme colour, using a lighter colour matching the theme colour. I am using the green theme version. Could you tell me which hex code that dark green of the meny marker is, so I can make a lighter match?
    regards,
    Jarkan
    Paste the following code in your custom css
    Appearance -> Theme Options -> Styling Options -> Custom CSS
    body {
    background: none;
    background-color: #50742c;
    you can put your color code instead of #50742c .
  3. jarkan
    jarkan New Member
    Thanks, much appreciated!
    Jarkan
