change blog section to products
Discussion in 'General InkThemes Discussion and Feedback' started by drifterzz, Oct 25, 2018.
  1. drifterzz
    drifterzz New Member
    On the home page it shows a slider with the most recent posts.....can this be changed to woocommerce products instead?
  2. akbar92
    Greeting from InkThemes,
    Just let me which theme you are using and send me the URL of your website.
    Then I will let you know it is possible or not.
    Akbar
  3. drifterzz
    fitno pro theme
    gitfitpensacola.com
  4. akbar92
    Yes, we can add the WooCommerce products instead of blog posts but this will include customization charges of about $50.
    As I consulted with our developers, this will need source code customization.
    So let me know if you want to carry out further.
    We will do the rest for you.
    Akbar
  5. drifterzz
    yes, I would
  6. akbar92
