Change border color of Home Page Feature Area Images when hovering with mouse?
Discussion in 'Blackriders WordPress Theme' started by gloryous, Jan 10, 2018.
  1. gloryous
    gloryous Member
    Greetings!
    Is it possible to change the border color of the Home Page Feature Area Images when hovering with mouse? When it pulses, I'd like to have a different color that's more complementary to the branding colors chosen for the client.
    Here is the area I'm interested in changing:
    Thank you in advance for your advice and help!
    Glory
  2. akbar92
    To make desirable changes, just paste the code given below in Custom CSS section.
    .feature_inner_box .circle:hover {
        background: #33d8b3;
    Or if you want to use different colors for each feature colon then use the below-given CSS codes:
    .first .circle:hover {
    .second .circle:hover {
    .third .circle:hover {
    .fourth .circle:hover {
    Hope this helps...!
    Akbar
    Note: You can use any color Hex code instead of #33d8b3 to set your desired color.
    gloryous likes this.
  3. gloryous
    gloryous Member
    Perfect, Akbar! Thank you!
  4. akbar92
