Change color below footer
Discussion in 'Dzonia WordPress Theme' started by wtrujillo, Jul 24, 2013.
  1. wtrujillo
    wtrujillo Guest
    I need to change the lighter color below the footer. Can you help? Thanks!
    It is not possible to change its color because it is an image not a color if you want to change its color then,
    Go to css > color > images present in your theme directory and replace your image with present pagination image or edit it.
    The name of image is "bottom-cornor-blue.png"
  3. wtrujillo
    wtrujillo Guest
    Is there a way to just remove that image? When I have tried to replace it entirely with a file of the same name, I'm left with a gap at the bottom.
    I've also tried to delete that file entirely (and not replace), but it still shows the same gap. Is there another file or some custom css I need to add?
    See image:
  4. Piyush
