Change color of Hyper links
Discussion in 'ColorWay WordPress Theme' started by scarn8881, May 13, 2013.
  1. scarn8881
    scarn8881 Guest
    How can I change the color of the Hyper links?
    possible color: # d305f7
    a {
    color: #d305f7 ! important;
  3. scarn8881
    scarn8881 Guest
    Thank you Piyush.
    This worked, however it changed the slider text box as well as other areas. I am just wanting to change the hyperlinks with in the body of the pages. Is it possible to just change those?
  4. Gourav
    Could you please explain your problem with the help of screenshot, where you want to change the hyperlinks color and also share the link of your website, so that we can give you the exact solution.
  5. kimharp
    kimharp New Member
    I would like to know the answer to this question as well! Can you let us know what worked?
