Change color of underlining in footer widgets
Discussion in 'GoldenEagle WordPress Theme' started by wesackerman, Feb 3, 2013.
  1. wesackerman
    wesackerman New Member
    Hello. I'd like to change the color of the underlining below the titles of the footer widgets. (I already changed the background color of the widgets with custom CSS.) Could you please let me know how to change the color of the underlining? Thank you.
    It is the image 'footer-line.png' through which the underline of the footer widget titile is shown.
    If you want to change the color than, go to the Theme directory > Images and replace your color image instead of 'footer-line.png' image in the image directory of the theme.
    Note that, you have to make the same name of your image as the name mentioned in the previous image.
    You will not get images directory in your dashboard.
    You can find the images directory through FTP.
    Open your Theme directory (through FTP) > images directory > 'footer-line.png'
    replace your color image instead of 'footer-line.png' image with the same name as previous, Then again upload it at the same place.
    Thanks.
