Change color or Read Review button?
Discussion in 'ReThink WordPress Theme' started by gloryous, Apr 18, 2015.
  1. gloryous
    gloryous Member
    Is it possible to change the color of the "Read Review" button to something specific; e.g., RGB or Hex color value? [Sorry if this was asked before. I couldn't find an answer through a search.]
    Thanks!
  2. sameerwalkar
    sameerwalkar Guest
    Kindly provide your site URL
  3. gloryous
    gloryous Member
    http://www.lowellroutley.com/
    I've changed the text of the "Read Review" button to read "Read More" ... I'd like to have more color options for the button than this aqua/mint green default color. [I also see it's a two-toned color, with darker shading at the bottom, which will probably require 2 separate colors.] Hoping this is possible. Thank you.
  4. sameerwalkar
    sameerwalkar Guest
    Kindly apply the below CSS. Also if you wish you can put your own color code.
    .product a.btn-2 {
      background-color: #9D1A1A;
      box-shadow: 0 3px 0 #9D1A1A;
    gloryous likes this.
  5. gloryous
    gloryous Member
    Thank you, Sameer!
