Change footer text and links
Discussion in 'ButterBelly WordPress Theme' started by rwmons, May 12, 2014.
  1. rwmons
    rwmons Guest
    Hi there!
    How can i change the default text in de footer? F.e.
    About Us
    We make simple and easy to WordPress themes that will make your website easily. You just need to install it and your website will be ready within a minute.
    I also want to change the names and url's of the hyperlinks in the footer:
    Thank you very much.
    You are talking about footer widget area, Go to the
    Appearance > Widgets
    Drag widgets and drop them in the first, second, third and fourth widget area, It will automatically display at your footer.
    Also check link for reference
    http://www.inkthemes.com/how-to-use-widgets-in-wordpress/02/
    Gourav Shrivastava
