Change Header Container
Discussion in 'BlackBird WordPress Theme' started by sspore520, Sep 3, 2014.
  1. sspore520
    sspore520 New Member
    How can I change the header color to a custom image instead of the default color options?
  2. Pramod
    Pramod Guest
    Please provide more information about it what you want to make change.
    If possible provide the screen shot of the section.
    Pramod
  3. sspore520
    at the top behind the "black rider" logo... I found css that allows me to link an image but it is too small and I tried to change the margins, but I either did it wrong or it didn't work....
  4. Pramod
    Pramod Guest
    You cannot set an image as background.But you can set different color for background.
    .header_container {
    background: green !important;
    Change color according to your need.
    Pramod
  5. sspore520
    fyi this works
    .header_container {
    background: #3da6c4 url(image url);
    greatscottfilm likes this.
  6. Pramod
    Pramod Guest
    Yes it work.
    You have to put exact URL of image which you want to set in background.
    Pramod
