Change menu dropdown background color for subpages
Discussion in 'HomeBuilder WordPress Theme' started by v4sb, Nov 6, 2015.
  1. v4sb
    v4sb Member
    I would like to change the color of the dropdown menu for subpages to something lighter, so that the words pop out better - or even change the color of the font on the dropdown menu for subpages. Either way, just need the words to pop out better and remove the shadowing around the text in this menu area. See attached photo.[​IMG]
    smith likes this.
  3. v4sb
    v4sb Member
    homesforsaleandrent.us (support has my login credentials already)
    #menu .ddsmoothmenu li li a {
        background: lightskyblue !important;
            color: red !important;
    #menu .ddsmoothmenu li li a:hover {
        background: lightyellow !important;
    Note: Change color as per your interest.
