Hello, Let me clear you that H1, H2 tags are Cufon over there.. So to change their fonts, firstly you have to disable Cufon Font Option under the General setting of Theme Option panel. Please follow the screenshot given below. After this, paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: h1,h2,h3{ font-family: 'Arial'; } Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
I have a similar problem, however there is no option to disable Cufon Fonts. How can I disable Cufon? Thank you
Hello, You are suggested to reinstall a fresh copy of the theme from the members area and check after that.. Hope it will resolve your issue Thanks & Regards! Priyanka InkThemes.com
