Hello, I would like to change the name of "Home" (circled with red in the provided picuter). Also, is it possible to change the font size of that same text? And change the padding at both bottom and top? Lastley I want to remove the sidebar widgets from some pages (not all). I look at this forum and found a code: .sidebar { display: none; } However that makes the widgets disappear on all my pages. I have downloaded the plugin widget logic that lets me put widgets on specific pages. But then I get 3 widgets I dont want (Search, Categories, Archives). My site can be seen at http://introteknik.nu/ Thanks in advance
As you can see on my page http://introteknik.nu/?page_id=91 I have put in a widget on the right "Testis" but I also have Search, Categories, Archives, which I don't want (and can't seem to remove in an easy way)
Hi, Greetings from InkThemes, It would be our pleasure to serve you. We are here with solutions to your issue. Let's fix them one-by-one. Regarding change of 'Home' text. Please follow the screenshot given below. Regarding change of font-size, top and bottom padding. Please paste the code given below in Custom CSS section(Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: div#crumbs { font-size: 20px; padding-bottom: 0px; padding-top: 0px; } Hope it will resolve your issue Thanks & Regards! Nitin InkThemes.com
