Change 'Read More' for Search Results
Discussion in 'GeoCraft WordPress Theme' started by spoonboy90, Jul 18, 2013.
  1. spoonboy90
    spoonboy90 Active Member
    Sorry to have to start a new thread but the other one was closed before I realised that it wasn't affecting search results...
    Where is the code to edit this text please?
  2. kentoliver
    kentoliver Active Member
    These are populated by a excerpt function that geocraft has created.
    I would suggest opening a code editor. Searching the entire folder for the phrase 'Read More'
    Then go through the selected files until you find the string you are looking to edit.
    I would use this procedure to find and change alot of things within the geocraft theme.
    Taking strings from within the theme, and then you can find whatever you are trying to find.
    I hope that helps. Too lazy to do all that myself.
    All the best,
    -Kent
  3. spoonboy90
    Thanks Kent, I've already tried to search for the relevant file and have changed several strings all which didn't seem to make any difference to anything, the one for the search still alludes me.
  4. Gourav
    Go to template_search.php present in your theme directory and follow the instruction as shown in image given below
  5. spoonboy90
    Thanks Gourav, could swear I seached that file!
