Change Sidebar Width of Posts
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by codered, Mar 14, 2018.
  1. codered
    codered New Member
    I would like to change the width of my post page sidebars. My site isn't live yet so just some instructions on where I should look will be fine for now.
  2. akbar92
    Thanks for contacting us,
    Akbar
  3. codered
    codered New Member
    Thanks for the quick reply. I've attached a screen shot. Basically I want to make the main column a little wider and reduce the sidebar width slightly. Even reducing the space between the main column and sidebar might also be helpful to know to know.
  4. akbar92
    Greeting from InkThemes,
    We need WordPress admin credentials to configure it.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will do it for you.
    Akbar
  5. codered
    codered New Member
    Thanks for the reply. I have sent through the login details as requested.
  6. Naveen
    We have got the login details but that didn't work.
    Please check your email and share the correct login details.
  7. codered
    codered New Member
    I sent the corrected login details in. Have you got those yet? I just double checked and these do work.
  8. akbar92
    Hope your issues have been resolved.
    Do let me know if we missed something on our end.
    Akbar
  9. codered
    codered New Member
    Akbar, your solution provided exactly what I needed along with the ability to make further tweaks if necessary. Again, thanks for the great support. It's always very appreciated.
  10. akbar92
