Change Slider "dot" and color behind circles when loading
Discussion in 'BlackBird WordPress Theme' started by revpjdunn, Dec 4, 2012.
  1. revpjdunn
    revpjdunn New Member
    Fort Worth, TX
    I am trying to place a custom color on the "dot" use use in the slider to select a slide. I also would like the background color of the circles to a custom color as well, it comes up yellow while it is loading. www.tableforoneministries.com.
    Thanks!!!
    Blackbird theme comes with ten different colors.
    Go to
    Appearance > Theme Option > Styling Option > Theme Stylesheet
    and select color scheme from there.
  3. revpjdunn
    Fort Worth, TX
    This did not correct the issue as it just changed the colors behind it to different ones. Is there any code I can paste to have a "none" value?
  4. Gourav
    Use recommended size of image in featured circle
    Recommended size is
     (158x165)px
    It will remove the loading problem from your site.
    Now,
    Paste this code in Custom CSS
    .feature-content-inner .circle img{
    background:none!important;
    revpjdunn likes this.
  5. revpjdunn
    Fort Worth, TX
    That worked! I also uploaded smaller .png files for the pictures.
    Any code to change the yellow slider button?
  6. Gourav
    Go to images directory present in your theme directory and replace your image with present pagination image or edit it.
    The name of image is "pagination.png"
  7. revpjdunn
    Fort Worth, TX
    Yall are the best! Thanks!!!!
