Change Slider Format and Other Front Page Questions
Discussion in 'BlackBird WordPress Theme' started by smellslikecanada, Apr 30, 2013.
  1. smellslikecanada
    smellslikecanada New Member
    Hi there,
    I'd like to modify the slider format on the front page of my site www.smellslikecanada.com, as well as some other things... I'm still learning...
    1. I'd like to modify the horizontal coin slider format to a horizontal one... I've downloaded a slider widget (Meta Slider) - is it possible to replace the existing slider with the widgetized one?
    2. I'd like to remove the slider description from the first slider image, but when I delete the text, the default Blackbird text comes up
    Thank you!
    1) It is not possible to replace current slider with any slider plugin. It require lot of customization.
    2) Just add blank paragraph tag in the description field like '<p></p>'.
  3. smellslikecanada
    Hi Nitesh,
    Is it at all possible to retain the same slider, but at least change the "buttons" along the side from vertical format to horizontal along the center bottom of the slider? The formatting looks sloppy when the size of the text box changes with each image.
  4. smellslikecanada
    In addition to the previous question - I added in the blank paragraph tag, but a blank shell of the black title bar still shows up - can I remove it completely from certain slider images?
