I would like to slow down the cycle of testimonials on the home page. Is there an easy way to do this?
Hi. I had the same question. When I change that number though, it just slows the transition from slide to slide. The length of each slide stays the same. Also, I can't figure out how to make the controls display. Nothing in the file seems to make them show. I would like the user to be able to pause the slideshow.
Hello mikem60! Unfortunately this is not possible in the theme to put a pause button on it. Thanks & Regards Pramod
