Changes to Bizway Pro
Discussion in 'BizWay WordPress Theme' started by dustin807, Aug 24, 2016.
  1. dustin807
    dustin807 Member
    Hello, I have a few changes that I'd like to make to my bizway pro theme.
    How can I delete the search bar from the top of the website header?
    How can I make the homepage image not clickable? Don't want it to be a hyperlink.
    On the home page, I don't want there to be a page 2 for blog posts. I don't want every blog post I publish to be in the homepage source code, only the 5 or so articles that I choose and that's it. How can I make that happen?
    1) How can I delete the search bar from the top of the website header?
    .top-search {
    2) How can I make the homepage image not clickable?
    Are you talking about the featured images..?
    3) On the home page, I don't want there to be a page 2 for blog posts.
    Could you please provide me 'URL' of your site along with some edited screenshot of the area so that we I better assist you?
  3. dustin807
    dustin807 Member
    For the homepage image not clickable, I'm talking about the first big image on the website. It's a bunch of people sitting at a table http://www.dustinsancheztv.com/
    I don't want there to be a page 2 for blog posts. I just want 5 or 7 blog posts to be featured on the home page. I also want to be able to make a page called "Articles" and let that be the blog page with all of my blog articles on it, but when I try to do that it just becomes another home page.
    To remove link, please follow the screenshot given below.
    If you don't want to show more blog page link on homepage,
    To show all post on your Articles page,
    You just all need to do is set blog template (right side of the page) for your Articles page..
  5. dustin807
    dustin807 Member
    Thank you. There is just one more problem. On the home page at http://www.dustinsancheztv.com/, in the HOME PAGE FEATURE AREA, the "Read More" buttons do not link to the URL's that I entered. Instead they link to dustinsanchezt.com/#
    If you click on the images, then those 3 images each link to the page that I designated, but if you click on the "Read More" buttons, it does not link to any page. How do I fix that?
  6. dustin807
    dustin807 Member
    Thanks for the help. Just one more issue. In the Home Page Feature Area, the 3 images are clickable, but the three "read more" buttons link to dustinsancheztv.com/# instead of the URLs that I designated in the backend of wordpress. How do I get those "read more" buttons to link to the same URLs as the images
    see home page at http://www.dustinsancheztv.com/
  7. priya
    Please follow the screenshots given below.
