Changing background color on pages
Discussion in 'Figero WordPress Theme' started by hender24, Feb 21, 2013.
  1. hender24
    hender24 New Member
    I would like to change the background color on my full-width pages. Possible?
    Paste this code in Custom CSS
    .content-main.fullwidth {
    background-color: yellow;
    Inplace of yellow you can put your required color.
  3. hender24
    hender24 New Member
    Thanks Piyush. That changes the color for the text area, but what about the background color outside of the text area? Right now the text area background is white, and the background outside of that is whitesmoke color. I would like it to be white so it all blends. Is that possible?
    Also, is there a way to delete the thin border around the text area so the text area and side are all blend together?
  4. Piyush
    It is not possible to change the background of outside the text area, in a particular page (i.e. fullwidth page). It will change the background of all the pages partially.
    If you still want to change the background than paste the following code in your custom css
    Appearance -> Theme Options -> Styling Options -> Custom CSS
    .fullwidth {
    background-color: white ! important;
    border:none;
    .content-container {
    background-color: white;
  5. galesburgpl
    galesburgpl Member
    I tried to use the above code to remove the border of the content container, but nothing changed. Is there something I'm missing?
  6. Gourav
    Can you please explain your problem with the help of screenshot, where you want to change the color and also share the link of your website, so that we can give you the exact solution.
  7. galesburgpl
    galesburgpl Member
    Apologies. The above code didn't work for me, but this code did:
    .content-main {
    background-color: white; border none;
    .content-info {
    border: none;
    So I should be all set. Thanks.
