Changing basic color
Discussion in 'ColorWay WordPress Theme' started by chiroar, Oct 25, 2012.
  1. chiroar
    chiroar New Member
    Want to change the color of the menu tab/dropdown menus and footer section from one of the basic to some custom colors?
  2. Harmeet
    Harmeet Support Staff
    We have given eight different color in the theme you can select from there. just go to
    Appearance -> Theme Option -> Styling Options -> Theme style sheet
    Select the color from here.
    Thanks.
  3. chiroar
    chiroar New Member
    I know about the 8 basic colors which don't really go with our logo colors. Is there a code to use in CSS to alter your basic color to something custom for the menu tabs and footer areas?
  4. Gourav
    Paste this code in Custom CSS
    #menu li.current-menu-item a, #menu li.current-menu-parent a, #menu li.current_page_parent a, #menu li a.selected, #menu li a:hover, #menu li.current_page_item a {
    background:red!important;
    #menu .ddsmoothmenu li li a:link, #menu .ddsmoothmenu li li a:visited {
    background: blue;
    .footer-container {
    background: red!important;
    .footer-navi{
    Put color values as per your requirement.
  5. chiroar
    chiroar New Member
    Thanks, worked great. As to a previous question, is there any way to add a little address/contact region to top right of colorway?
  6. Gourav
    To achieve this you can add a banner which contain your logo image at the left side and your contact image at the right side and upload it as a logo.
    Use photoshop to do that.
