Changing Browse Listings to Text
Discussion in 'HomeBuilder WordPress Theme' started by suhayla, Feb 19, 2013.
  1. suhayla
    suhayla New Member
    I have just bought this template, after the correspondence below:
    You cannot change the text with the help of theme option panel but we will tell you the position in the file from where you can remove the code of "Browse Listing" And can add your text in it. And you can change the color of the text of the menu but you can't change the color of the orange dot below the menu item because the image is used in that. So we will help you to change the color of the text in the menu.
    Can you guide me on change the code and colour.
    Many thanks,
    Suhayla
