Changing color of theme to hex color
Discussion in 'Infoway WordPress Theme' started by helen_reeves, Feb 20, 2015.
  1. helen_reeves
    helen_reeves New Member
    Is it possible to be specific with the color of the theme #ff0099 for example?
  2. praveen
    praveen Support Staff
  3. helen_reeves
    Your reply
    We know that it was for Geocraft Pro Theme.
    The process is same for Figero.
    Go to Appearance=>Theme Editor and under Color folder edit the selected color css file(e.g blue.css).
    Can you be more specific I can't see Color folder! Please see screen grab.
    Thanks Helen
  4. Pramod
    Pramod Guest
    Hello !
    Please follow steps to change theme in another color.
    Before changing the theme color we will confirm you that if any images is required in theme apart from the color present on theme option=>styling option=>theme stylesheet(select color) is not available.
    You have to adjust with one of that color images.You can find the folder from you dashboard with the help of wp editor plugin.
    After wp editor plugin installation you will find all files of theme from Appearance=>Theme editor.
    Steps to change whole theme color apart from options available.
    -Select a particular color of theme from theme option=>styling option=>theme stylesheet(select color)
    -Open that file and replace all the color used in that file with your own
    eg. if you select green then search all green code and replace them with your required color.
    If you want to make changes in color in selected part then you can provide us edited screenshot with web URL and color which you want to use.
    We will help you to change color by custom CSS.
    Pramod
  5. helen_reeves
    I have installed WP Editor Plugin. There is a warning not to change theme when running theme!
    Could you help with custom CSS for whole theme colour change please?
  6. Pramod
    Pramod Guest
    Hello !
    For this please provide URL of your live website with some screenshot of website contains hint where to make changes..
    Pramod Patel.
  7. helen_reeves
  8. praveen
    Hi helen !
    .topinfobar {
    background: #339900 !important;
    #menu li:hover a, #menu li.current_page_item a {
    .content-bar .post .post_content .read_more {
    .footer-wrapper .footer {
    Praveen
  9. helen_reeves
    Thank you, how do you replace the small arrow image in the top bar to match please?
  10. praveen
    Hi helen,
    Go to "infowaytheme/color/images" folder and replace the "toptip-darkgreen.png" with your image.
    But remember the name of the new image must be same as the replaced image.
    Praveen
  11. gideman
    gideman New Member
  12. praveen
    Hi gideman!
    .footer-navi {
      background: green;
    Please change background color according to your requirement.
    Praveen
  13. gideman
    gideman New Member
    Hello Praveen,
    thanks, it works.
    Now I only have a second color above these footer-navi which is a dark red color, how can I change that color?
    Greetings
    Gert
  14. praveen
    Hi Gert!
    .footer-container {
    background: gray;
    Please provide us some edited screenshot if you need any further assistant.
    Praveen
  15. gideman
    gideman New Member
    The "container" was the one I hadn't found..
  16. gideman
    gideman New Member
    Hi Praveen,
    I can't find the question I am about to ask you now.
    I have changed several things with colors now, but now my site is transparent? I don't know how it happened and I can't find I way to switch it back.
    Can you help me with that?
    Greetings
    Gert
  17. praveen
    Hi gideman!
    Please download and install a fresh copy of this theme.
    This will resolve your issue.
    Praveen
  18. gideman
    gideman New Member
    Hello Praveen,
    where can I download a newest copy and if I install this new copy wont I loose all the changes I made?
    Greetings
    Gert
  19. praveen
    Hi Gert!
    Please send us your website wordpress login details at [email protected].
    Also, please let me know if you have made any changes/customization in any file of the theme.
    Praveen
  20. praveen
    Hi Gert!
    We have resolved your issue.
    Please have a look at your website.
    Praveen
