Changing color stylesheet
Discussion in 'Infoway WordPress Theme' started by jjelinek, Feb 3, 2014.
  1. jjelinek
    jjelinek New Member
    I like the stylesheet blue.css in the color directory but I want to change the color codes a bit. Should I customize this file with my color codes or should I override the CSS in the theme options?
    Also, the images that come with the blue theme such as the topinfobar and social icons. I assume I can make a copy of those images, rename them, change the color to match my color codes, and edit the css with the appropriate image names?
    Thanks in advance.
    Yes you can change blue.css according to your choice.
    And for images:
    You can edit existing images or can replace your own images with existing images but keep there name same.
    Nitesh Raghuwanshi
