1. How can I change the colors for the following: - header - navigation - click here button in header - buttons in homepage widgets - quotation mark at bottom for testimonials - link colors - widget headers on secondary pages (that little line above each widget) 2. Is it possible to add a social media icon for yelp in the top bar? 3. How can we stretch the words across the footer?
Hello, 1) Header header { background-color: #fff; } Navigation Code: #menu li:hover a, #menu li.current_page_item a { background-color: YOUR COLOR VALUE; } Code: .topinfobar .siteinfourl p { background-color: YOUR COLOR VALUE; } Button for sidebar widget Code: .signupForm .signinForm input[type="submit"] { background: YOUR COLOR VALUE; } Quote image. It's an image. If you are using theme default orange color then go to the infowaytheme\images and edit that image. And if you are using other colors then go to the infowaytheme\color\images and edit image. Link color. Code: a{color; YOUR COLOR VALUE;} Widget header color. Code: .sidebar h3 a { color: YOUR COLOR VALUE; } .footer .footer_widget h4 { background: url(images/footerheadsep-pink.png) bottom repeat-x; color: YOUR COLOR VALUE; } Social icon. You can replace any one from existing icons with the yelp icon. For it go to the infowaytheme\images and replace non useful icon. Footer text. Code: .footer p{ font-family:18px; } Thanks & Regards Nitesh Raghuwanshi
1. How do I update the color of the "Click Here" button in the header? 3. I'm a little unclear on what to do in order to make the words in the footer stretch across the bottom. Can you please elaborate? Thanks!
Hello, 1) Please share screenshot of the "click here" button. 2) To stretch footer text open footer.php file and make changes as shown in the image attached. Thanks & Regards Nitesh Raghuwanshi
