Hi, I love this theme! Here is a link to my site. I changed the background color. How do I change foreground color & other colors? For example, how do I change? 1. The default white foreground color? 2. The Header background color 3. The Navigation colors etc……..
Hello, Paste this code in Custom CSS Settings > Theme Option > Styling Option > Custom CSS Code: div.wrapper { background: yellow; } #menu .ddsmoothmenu li { background: none; } div.menu_wrapper { background: blue; } Thanks & Regards Gourav Shrivastava
What are the list of words for colors that I can input? The custom css does not seem to recognize every color on here by name. Also, can I simply write "none" if I choose a default color?
Hello, No need to add none. Just add Hex code of color you want to add for background. Thanks & Regards Nitesh Raghuwanshi
Thank you. 2 Questions 1. What if I want to change the color in the TOP HEADER ONLY. If you look at the attachment. The top & the bottom are both yellow. How do I make the top header the color of my choice? 2. What if I want to add something that is not a hex color #? Can I add an image of a gradient or a photo like a sunset? I have attached a photo of a header that I like. It uses a gradient and 2 different google fonts. I have also attached a photo of a sunset. 2A How can I upload a gradient like this? What dimensions should I make it? 2B How can I use 2 different google fonts within the same header? I don't want this to change other fonts throughout the website. I am only focused on the header area. 2C I included an image of a sunset. How do I place an image in the header only? What dimensions should I make it?
