Hi, I'm using the 'Green' setting for colour, but I'm looking for a deeper green. The parts I'm looking to change are: - Hyperlink colour - Button on Slider Colour - Background Colour of Slider Text See attached screenshot. Thanks!
Hi, Greetings from InkThemes! You can easily change the colours of the concerned areas as follows: To change the colour of the Button on Slider just paste the code given below in Custom CSS section (Dashboard -> InkThemes -> Styling Options -> Custom CSS) of your dashboard. Code: .layered_slider .slider-btn2:hover { background: #385d04; } To change the background colour of Slider Text just paste the code given below in Custom CSS section (Dashboard -> InkThemes -> Styling Options -> Custom CSS) of your dashboard. Code: .carousel-text h1 { background: rgba(56, 95, 5, 0.98); } Regarding the Hyperlink colour, please send us the screenshots of the desired area. I will give you the code for the same. Hope this helps...! Thanks & Regards, Shruti Jain InkThemes.com
Thank you. This worked fro the slider text background and the slider button hover colour. How do I change the colour for when you hover over the feature items?
Hi, You can change the color of the desired section from your Dashboard itself. Just select a color from different available colors, follow the steps : (Dashboard -> InkThemes -> Styling Options -> Theme Stylesheet). Hope this helps...! Thanks & Regards, Shruti Jain InkThemes.com
Thank you. I am aware that I can change via the "Theme Stylesheet" option, but I'm looking to change the shade of green to match the brand. Similarly the hyperlinks are green, but the wrong shade. Can I not do anything through cutsome CSS like I did for the slider text background solution you gave initially? Thanks!
Hi, Hope you are doing good...! Please provide the complete details ( screenshots/ site URL/ color code which you want ). I will give you the code for the same. Looking forward to your reply. Thanks & Regards, Shruti Jain InkThemes.com
