Changing CSS
Discussion in 'ColorWay WordPress Theme' started by rulob1984, Jun 12, 2014.
  1. rulob1984
    rulob1984 Guest
    In the theme folder I see there is a style.css file. I'd like to make a couple of changes to few things that will be used in the site and have to have same characteristics.
    Is there a problem if i change the CSS file? Will the changes be reflected in my elements throughout the site?
    Or should i use the custom css text area?
    Regards, Raul
    We suggest you to use Custom CSS text area for adding your css.
    Gourav Shrivastava
  3. ron1343
    ron1343 Guest
    I've taken code from many suggestions here in the forum and put them in the Custom CSS text area you're talking about, but it seems to not change a thing. Is there a bug with this section?
  4. Pramod
    Pramod Guest
    Hello ron1343,
    Please copy your all css you have used in your custom css box and do paste here.
    May be any syntax error in css code.
    Thanks & regards
    Pramod
  5. ron1343
    ron1343 Guest
    #content_wrapper .title {
    #content_wrapper .post_title {
    .border_strip {
    background: none;
  6. ron1343
    ron1343 Guest
    I got frustrated and just changed some things in the CSS stylesheet. I know that's a no-no, especially since I didn't create a child theme. I'm a mess. :) But I noted everything I changed in a word doc, and where it was changed. Am I still screwed?
  7. Pramod
    Pramod Guest
    Please do post the issue for which you are using above CSS.
    Your above code's syntax is perfect. Child theme is not required.
    Thanks & Regard
    Pramod
  8. ron1343
    ron1343 Guest
    Child theme is not required but I did go in and change in the stylesheet directly. So I can't undo that.
  9. Pramod
    Pramod Guest
    Hello ron1343,
    Please explain your issue for which you are looking CSS code.
    Thanks & regards
    Pramod
  10. usefulid
    usefulid New Member
    I am having the same issue. I cannot update any CSS via the custom CSS section. This is quite frustrating. I have taken code snippets from some of your other posts and they do nothing at all. The most recent example being:
    .logo {
    margin-top: 35px;
    .header .menu-bar {
    margin-top: 20px;
    margin-bottom: 5px;
  11. Pramod
    Pramod Guest
    Hello usefulid,
    Please provide your website URL.
    Pramod
