Hi as I am sure you are aware the default setting slugs for adverts pages and categories being /ad/ and /cate/ are a big problem for users. Has this issue been resolved? If so what is required to change these to something else? If this require custom coding can you please direct me to what areas of the theme need to be changed and if you have or know anyone that has done this successfully. The theme is working OK for me but this is a BIG problem for me and I need to resolve it in order to keep using them theme ongoing? Many thanks Joel
Hello, I certainly understand your concern about the subjected issue. But if you remove the slug and kept your own, then all the content associated with that slug will not be accessible any more and then you need to rework again for the same content for new slug defined. So it is suggested to avoid customizing the slug. Still if you wish to do, let me know, I will guide you accordingly. Let me know your opinion.
