changing font color and size
Discussion in 'ButterBelly WordPress Theme' started by mckinlt, Apr 1, 2017.
  1. mckinlt
    mckinlt Member
  2. Naveen
    I am afraid to say that, I was unable to locate the area in your sites.
    It would be better for us to understand your query with the help of edited screenshot.
    Naveen Kolhe
  3. mckinlt
    mckinlt Member
    Original font and color I like (Black and smaller)
    Default font and color I need to change (need it to be black and smaller)
  4. Naveen
    For this, you need to paste the below custom CSS code in Dahshboard->Appearance->Theme Options->Styling settings->Custom CSS field.
    h1, p{
    color:#000000;
    Warm Regards!
    Naveen Kolhe
  5. mckinlt
    mckinlt Member
    Perfect. Thank you!
  6. Naveen
    You are most welcome:)
