Changing H1, h2 colors
Discussion in 'BizWay WordPress Theme' started by tekkentim, Jan 23, 2013.
  1. tekkentim
    tekkentim Guest
    Hi Everyine,
    I've searched the forums for this, but no succes.
    I'm kind of tired to change all the text manualy with an editor, so i want to override the color for the h1 h2 etc tags. Is there a way to override ? Can someone provice me the css code ?
    I also want to change the color of links ( not the links in the top nav bar ).
    thnks !
    Can you please explain your problem with the help of screenshot, where you want to change the color and also share the link of your website, so that we can give you the exact solution.
  3. Piyush
    Paste the following code in your custom css
    Appearance -> theme options -> styling options -> custom css
    h1{
    color:red ! important ;
    h2{
    color:green ! important ;
    .footer_widget a{
    color:pink ! important;
    .footer_bottom_content a{
    color: pink ! important;
    this will solve your issue.
    Thanks.
  4. tekkentim
    tekkentim Guest
  5. Piyush
    .sidebar h3 {
    color: blue;
    .sidebar a{
    color:red ! important;
    This will solve your sidebar issue.
    thanks.
  6. tekkentim
    tekkentim Guest
    Thx ! you're the best ;-)
    Only problem i got right now is chaning the color of links, only for text links, not the links in the nav bar..
    Any ideas ?
  7. Piyush
    Please specify your issue more clearly with the help of screenshot image , where and which text links you want to change the color, so that we can provide you the exact solution.
  8. tekkentim
    tekkentim Guest
    Hi Piyush.
    First page, this text:
    You see the dark black links ? I want the color for these links changed, on every page. They are dark black now, and it really looks nasty ;-)
  9. Piyush
    .content-bar a{
    color: rgb(185, 91, 91);
    font-size: 12px;
    font-weight: normal;
    Thanks.
  10. tekkentim
    tekkentim Guest
    Tried it.. didn't work.. the text links are still black.. ( see my front page, links in beneath first H1 header )
  11. tekkentim
    tekkentim Guest
    Never mind !! it works !! great, thx !!
