Changing header and paragraph fonts
Discussion in 'Squirrel WordPress Theme' started by karibou, Sep 29, 2016.
  1. karibou
    karibou New Member
    Hi, can I get some help to change fonts in squirrel?
    The site is www.abluersky.com
    I would like to change the h1, h2 and h3 fonts to Herculanum.
    Also change the paragraph font size to 12 and type to Arial
    I checked your site and would like to inform you that you are using old version of the theme.. so please upgrade your theme with the new version.
    After that, please paste the code given below in Custom CSS field of your dashboard.
    h1, h2, h3, h4, h5, h6 {
        font-family: 'Herculanum';
    p {
        font-family: Arial;
  3. karibou
    karibou New Member
    Thank you, I will update the site. Thanks for the code to change the fonts, much appreciated!
  4. karibou
    karibou New Member
    Another question...where do I edit out the "Just another WordPress Site" phrase?
    Thank you
  5. priya
    Would you please share screenshot of the concerned area so that I can better assist you..?
  6. adaptaero
    adaptaero New Member
    I am trying to accomplish the same task. But I cant seem to find "custom.css" file
    WARNING! DO NOT EDIT THIS FILE!
    To make it easy to update your theme, you should not edit the styles in this file. Instead use
    the custom.css file to add your styles. You can copy a style from this file and paste it in
    custom.css and it will override the style in this file. You have been warned! :)
  7. nitin
    nitin Guest
    You can easily change "Just another WordPress Site" phrase.
    Once you're logged in, you can find the "customize" option on the top in the admin bar.
    When you'll click on 'Customize', A panel will get opened on the left side.
    You will find 'Site Identity' in this panel. Click on it.
    Edit the Tag Line and Save.
    And it's done.
    Hope it will work.
    Thanks & Regards,
    Nitin
