Changing Menu Label Cases
Discussion in 'InkThemes-Support Working Hours' started by adammacha, Nov 1, 2015.
  1. adammacha
    adammacha New Member
    I am using Traffica Theme Pro.
    1. I need to be able to Change Menu Label Case from Capital to Mixed Case ( Capital and Small letters )
    example CUSTOMER SERVICE , i should be able to write Customer Service
    2. How do i make the Footer Line more than 64 characters before getting to next line.
    for example www.luwasa.or.tz , i need the whole text to be in one line. like this
    © Copyright 2015 LUWASA. All rights reserved. Designed By Adam & Adrian (T) LTD
    1) I need to be able to Change Menu Label Case from Capital to Mixed Case
    For this, you just need to Please paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    #menu .ddsmoothmenu li a {
        text-transform: initial;
    2) I need the whole text to be in one line.
    Fo this, paste code given below in custom CSS field of your dashboard..
    .bottom-footer-container .bottom_footer_content .bottom-inner-footer p {
        width: 546px !important;
  3. adammacha
    Thank you very much.
    All went well.
    Adam Macha
